Honda accord 98 still shifts erratically and now overheating
Old Dec 10, 2019 | 10:26 AM
Rilex's Avatar
Default Honda accord 98 still shifts erratically and now overheating
Good day to you all in the forum, after cleaning the solenoids the car still shift erratically both upshifts and downshifts with large bang more severe when the temperature is hot outside. This morning I drove to a place about 25km it shift smoothly and no banging at all. But on coming back home around 2pm this afternoon it begins to shift erratic and it wasn't comfortable for me to drive and I discover the temperature gauge rose high I have to stop. I checked the radiator it wasn't leaking and both fans are working perfectly. As it is now I cannot travel long distances with the car. I don't know why it was overheating, I am thinking because of the stress imposed from the gear irregular shifts on the engine making it to overheats. I am planning replacing both the engine and the auto transmission by January next year.
Any useful suggestion from members in the forum will be helpful.
Thanks
Old Dec 10, 2019 | 04:23 PM
The Toecutter's Avatar
Thanks
If cleaning the solenoids didn't fix it, it's probably shot. Was it slipping and staying in lower gears driving home in the afternoon? If so, that was the cause of your overheating. Sounds like a transmission replacement is in your future sooner than planned
Old Dec 10, 2019 | 05:10 PM
When your engine temperature gets hot, turn the heat on full blast inside the car to help cool it down.
How dirty were the solenoids?
When the engine is cold, remove the radiator cap and verify the radiator is full of coolant. Let us know if you have to add coolant.
Are you planning on replacing the engine/transmission next month?
Old Dec 11, 2019 | 03:07 AM
Rilex's Avatar
We did clean the small filter inside the solenoids. Is slipping and slowing in lower gear in hot afternoon. You said is "probably shot" I don't understand. I am looking forward getting another engine/auto transmissione. Is being 7 years using using the car and no problem so far
Old Dec 11, 2019 | 03:17 AM
Rilex's Avatar
The solenoids filter was actually dirty, how do I test for good functioning solenoids. It slipps and slow in lower gear in hot afternoon. You said is "probably shot" I don't understand can you explain. I am going for another engine/auto transmission
Old Dec 11, 2019 | 10:25 AM
UhOh's Avatar
"probably shot" is an informal way of saying something is broken beyond easy repair.
Luck
Old Dec 11, 2019 | 01:10 PM
Luck
Exactly. Also why I said the trans replacement is in your future sooner than planned (won't make it to January).
Old Dec 13, 2019 | 12:59 PM
Rilex's Avatar
I have another Honda car 1990 model parked for 7 months now I wil try to fix it, the automatic transmission is still functioning the only problem is the leaking engine which can easily be done by the mechanic. I will save money for used engine/automatic transmission for replacement in my Honda accord 1998 model by January ending. The car body is still very good and neats, I prefer Honda cars due to spacious environment inside. I do hope to get good engine/auto transmission that will last at least for 3 years. I am making necessary arrangement and negotiations on the cost here in Nigeria.
Thanks
Rilex
Apr 20, 2013 10:27 AM
iStagl
Jun 29, 2012 11:41 AM
pyuniverse
Mar 23, 2011 01:19 PM
japo2336
Jul 16, 2007 09:49 PM
93Accord10thYear
Jun 21, 2006 05:43 PM
