Honda accord A/C Speed issue
Old Jun 13, 2009 | 11:31 AM
rikleo2001's Avatar
Default Honda accord A/C Speed issue
Hi
I have Honda Accord, 1999, 2.0ltr saloon 4 door, automatic.
My AIR-CON is blowing right amount of cold air, but not with speed hence my car is not getting cold enough during hot weather.
I have 4 speed control fan, on 4 I am getting very slow blow of cold air, Air-con is recharged recently with no leaks..
what should I look now to get the full speed of my fan back?
Please help
Many Thanks
Old Jun 14, 2009 | 08:15 PM
hondadude's Avatar
Well first .....
Can you hear the fan change speeds?
Have the filters ever been changed?
Old Jun 15, 2009 | 02:38 AM
rikleo2001's Avatar
Hi Thanks for your reply.
Yes, I can hear fan changing spped.
Are you talking about cabin air filter? I don't think so it ever change, I had it for 2 years now, I never done that...is there any link which I can follow to do it my self?
Many Thanks
Old Jun 15, 2009 | 07:14 AM
The word "saloon" tells me you're in the UK??
Different car vs. our USA Accord, but on ours, the cabin air filter is forward of the glovebox. It's a bit of a pain to remove the glovebox, and there's a stamped steel bar across that has to be removed also. Then the cabin air filter is inside a tray that simply un-clips and slides out from the air duct.
But I really have no idea how they re-arrange things when the steering wheel is on the right.
Old Jun 15, 2009 | 11:27 AM
00AccordLX5spd's Avatar
Registered User
is it the same when you have the recirculate button pressed and when you do not have it pressed?
Old Jun 16, 2009 | 02:32 AM
rikleo2001's Avatar
First of all many thanks for your help.
I think cabin air filter is at the same location under glove box, I checked some articles on web, but I would really want a video tutorial, if possible.. This is first time I am doing this stuff, so thanks for your help.
Now when I have recirculate pressed it makes noise like a jet but no differance in fan speed and came back to normal when I have it unpressed?
Is there any possibility that I might have Short circuit motor? which is running on 2/3 speed hence not running at full power? leaned from article?
Thanks again.
socaldave34
Oct 18, 2012 06:09 PM
anti3025
Apr 1, 2012 11:33 PM
irhunter
Mar 23, 2011 04:49 PM
Spadinator
Oct 23, 2010 12:50 PM
Mott
Apr 9, 2010 07:40 AM
