Honda Accord crank pulley shifting
Old Dec 5, 2012 | 03:50 PM
EnriqueMxli's Avatar
Default Honda Accord crank pulley shifting
Hello,
I have a 1998 honda accord LX. Recently they changed the crankshaft pulley. The pulley was shifting side to side and making a rattling noise. When they changed it, they showed me the old one and you could noticed the teeth were very flat and the rubber worned out. They changed it. The car has been running good, the noise went away, but I still notice the crank pulley shifting about half an inch from left to right. What could be the cuase of this. Has my crankshaft gone bad? Is it because I didn't buy an OEM crank pulley? I bought the Dorman brand.
Please advice.
Thank you,
Enrique
Old Dec 5, 2012 | 07:48 PM
Dorman makes pretty good stuff IMO.....so I'm worried that either the "snout" of the crank has damage...or the new one got damaged.
Use a marker and draw a line from the inside of the pulley to the outside ring. Run the car for a bit of time....then re-sheck the "line".....is is still lined up or did it move?
Old Dec 6, 2012 | 08:37 AM
Dr. Drivability's Avatar
i think his "shifting side to side" is being mistaken for a wobble? damper may not be seating completely?
Old Dec 6, 2012 | 02:51 PM
How about shifting "side to side" w.r.t. the car. That might be excessive end-play in the crankshaft??
Enrique... Is that what it's doing? Pulley moving in & out from the engine?
Old Dec 7, 2012 | 06:58 PM
[QUOTE=JimBlake;304464] Jim, yes it looks like it moves side to side moving away from the engine, not by a lot but it is noticeable, and I'm afraid that in the long run this might be a bigger issue.
Old Dec 7, 2012 | 06:59 PM
- I will try this and let you know of the results.
Old Dec 8, 2012 | 10:59 AM
...that would be a wobble
Old Dec 9, 2012 | 10:45 AM
Well, lets clarify things...
Wobble would be (for example) a bad crank pulley, it's not straight & true. So they pulley wobbles as it spins.
What I was afraid of, is loose thrust-bearings on the crankshaft. In that case the crankshaft itself is shifting axially in it's bearings. It doesn't wobble with each revolution of the crank; it moves more slowly and straight in & out.
SirJohnIII
Oct 7, 2014 09:46 PM
Neptun3
May 3, 2013 06:18 PM
Doug Grellner
May 12, 2012 12:17 AM
thedreamer
Jul 6, 2010 03:48 PM
accordfan222
Oct 14, 2007 07:19 AM
