Honda accord problem. help?
Old Mar 10, 2012 | 10:48 PM
HodgHonda's Avatar
Default Honda accord problem. help?
Hi i have a 1995 honda accord ex 2.2 i got it like 3 months ago and its a 5 speed when ever i hit 3500 Rpms it stops and acts like it hits a rev limiter in ever gear it does that it has did that ever since i got it im not sure why the only thing i can think of, is someone put a auto ecu in it, would that be a problem? or if you think its something diffrent let me know thanks
Old Mar 11, 2012 | 07:32 AM
Is Check Engine Light (CEL) on? If yes, I believe your car may be OBD2 compliant and you can extract codes w/ a scanner (autozone, et al). If not, see DIY section for guidance on manually extractiing CEL codes.
Old Mar 11, 2012 | 09:19 AM
A stock 95 is OBD-I......connector under the glove box.....no port behind the ash try.
Old Mar 11, 2012 | 01:40 PM
bensminger2003's Avatar
I would think that an auto ECU in a manual trans car would be an issue because the ECU is looking for the extra sensors that the auto trans would have. I would put an ecu from a manual trans back into the car and see if this corrects the issue. My thinking on this is if you pull the codes, they may be false codes since the incorrect ECU is installed.
Jae Min Chang
Sep 17, 2013 04:23 PM
jkrueger2020
Mar 10, 2011 02:18 AM
mamtsberg
Mar 17, 2010 09:15 PM
kellysa111
May 1, 2009 08:35 AM
eddyfurukawa
Feb 13, 2006 03:15 PM
