honda accord sixth gen- couple of questions
Old Apr 11, 2018 | 08:45 AM
Eran Teitelbaum's Avatar
Default honda accord sixth gen- couple of questions
hello
1) i bought a salvage car for spares and wanted to test the auto tranny, so i jacked it up and removed the wheels, and revved the engine, but it wouldn't shift up from 1st.
also when i put it in N the rotors were still turning.
is this test reliable? maybe it's normal because there wasn't any load on the tranny?
2) what's the purpose of the funny curly part under the air intake hose? my car doesn't have it, the salvage car does, and i need it's hose.
3) i'd like to install an oil cooler for the tranny, so which hose is the return line from the radiator?
thanks.
Old Apr 11, 2018 | 03:24 PM
The Toecutter's Avatar
Originally Posted by Eran Teitelbaum
hello
thanks.
I don't know if that's a good test for the trans. I'd think it would need some sort of load on it.
The "funny curly" part is an air baffle to help silence the incoming air to the engine. You can leave it on. It won't hurt anything being in place. You might have to figure out the best way for it to sit.
I believe it's the center line that is the return. Are you going from out of the rad to the cooler, then back to the trans line? That'll work just fine.
I'd also add an external filter in that line as well so you can filter out the trash in the fluid. Keep in mind that anything you do to help cool the fluid, and keep it clean will help these transmissions (key to long life).
Old Apr 11, 2018 | 04:57 PM
yes, from the radiator to the cooler and back to the tranny.
the center line- you mean the one closest to the engine?
Old Apr 12, 2018 | 01:29 PM
If you look at the bottom of the radiator, the one on the left side (drivers side of the car) is more centered and the line you want.
Old Apr 24, 2018 | 08:10 AM
well, mine is probably different. there's a line under each fan, no one of them is more centered than the other.
one line goes from under the cooling fan and connects to the tranny more or less under the starter motor, the other one goes from under the a/c fan and connects to the tranny under the thermostat.
Old Apr 24, 2018 | 12:57 PM
Well, it's the line closest to the left (drivers side) of the car.
Ryanj1008
Feb 7, 2014 04:28 PM
dtm888
Apr 22, 2012 11:41 PM
Jet sitter
Apr 18, 2012 09:24 PM
TorontoGuy
Oct 26, 2007 11:05 AM
