Honda Acoord 2003 AC not working
Old Jan 14, 2013 | 03:53 PM
infectedmushroom22's Avatar
If you can get or buy one (seen some for as little as ~$5) test the AC Pressure switch. Should be continuity on the "pins" of the switch, is there?
Next would be to test for voltage (~5v) on one side of the wires with the car on and the AC on.
Where is the AC pressure switch? sorry bit of a newbie here.
Old Jan 15, 2013 | 07:50 PM
Right/pass side of the cond - low/bottom.
As stated already. If you do not have continuity on the pins on the switch. Either the ac pressure is low or you have a bad switch.
If you have continuity on the pins...we need to do more tests.
Attached Thumbnails Honda Acoord 2003 AC not working-7th-gen-4-cyl-ac-press-switch.jpg
Old Jan 15, 2013 | 08:12 PM
Go to the common diy thread on top of the gen tech help forum. Under the 03-07 accords, there is a link to HVAC codes. This is simple to try. If you do or don't get a code, let us know.
Old Jan 17, 2013 | 10:45 PM
I checked the voltage on the connection right adjacent to the radiator and it gave out 12v
Old Jan 21, 2013 | 10:32 AM
Old Jan 21, 2013 | 11:23 AM
Now test the A/C pressure switch for continuity (as poorman212 stated).
Use a continuity test light, ohmmeter, or multimeter to test for continuity between the pins on the switch.
Attached Thumbnails Honda Acoord 2003 AC not working-ac-pressure-switch-continuity-test.jpg
Old Jan 22, 2013 | 11:11 PM
  #17
so i tested both the terminals on the switch using a voltmeter and i got the beeping sounds. which i am assuming it closes the circuit.
Old Jan 24, 2013 | 08:25 PM
  #18
any more suggestions guys?
thank you
Old Jan 26, 2013 | 09:18 AM
  #19
I can only assume your "beep" means there is continuity.
Turn the key on and the AC and blower on, measure the voltage on the BLU/RED wire to body ground. What voltage are you getting.
Old Apr 16, 2013 | 01:59 PM
  #20
So after months of messing with it... the problem is electrical. If i short the relay under the hood everything works fine. I have replaced all the relays and that has not fixed the issue.
But i Cant have the relay short 24/7 since it activates the clutch and that could drain my battery over night.
I just hope no one has these issues, especially during the texas summer.
