Honda Acoord 2003 AC not working
Old Apr 16, 2013 | 02:21 PM
  #21
Dr. Drivability's Avatar
bad idea to leave it jumped for more than 30 seconds, a continuously running compressor will be damaged. sounds like the control head is not sending the A/C request signal to the system. recheck for codes, i bet you find one or more.
Old Apr 17, 2013 | 02:17 PM
  #22
infectedmushroom22's Avatar
I will be taking it to the dealership this weekend. Will update you guys on what the root cause of the problem is.
I knew leaving it jumped would be a bad idea. Hence I havent been driving it around much.
Old Apr 17, 2013 | 04:46 PM
  #23
EXV6NIGHTHAWK's Avatar
Did you check the clearance on the compressor clutch? My A/C would blow cold for a few minutes then stop. Had the stator and clutch changed at the dealership. Another guy said he was able to change the clutch with the compressor still in the car, but with the location of the compressor caused me to chicken out, and let the dealership do it. Cost me $600.
Old Apr 17, 2013 | 05:18 PM
  #24
Hang on....How are you "jumping" the relay? Are you pulling it and adding a wire to two of the four terminals to send power to the compressor......? Wish you had a testlight or volt meter. Can you show a picture of the two you are jumping?
kaneman
Feb 3, 2015 01:05 PM
foregel
Mar 3, 2014 09:11 AM
brinriha
Jul 2, 2008 09:28 PM
DA KID RYU
Feb 27, 2008 10:43 PM
nwj917
Jan 17, 2008 01:24 PM
