Honda A/C Gurus needed!
Old Aug 12, 2012 | 06:46 PM
joeldaugherty's Avatar
Originally Posted by PAhonda
Check for 12V on the blu/wht wire at the blower motor like I mentioned before using a volt meter. There should be power with the key in the II position.
I might consider returning the new aftermarket blower resistor and getting one from the Honda dealership. Aftermarket parts can be bad out of the box.
Yep, I get about 12V at the wire harness to the blower. Volts don't change though when the fan speed is pushed up or down, so idk what that means. The blower kicks on for like a second when the key is in II position. Parts guy pulled resistor for a four-door (or so he said). You think it could still be the resistor?
Old Aug 12, 2012 | 06:55 PM
It is either the transistor (the new part), the HVAC control, or much less likely the blower motor relay (since you have 12V on the blu/wht wire).
A quick test for the blower motor relay (#1) is to switch it with the a/c condenser clutch relay (#2) in the engine bay fuse box. See attached picture.
Attached Thumbnails Honda A/C Gurus needed!-fuse.jpg
Old Aug 12, 2012 | 07:25 PM
Already tried switching relays (#1) and (#3). (#2) doesn't fit. Maybe it's the HVAC control?
Old Aug 13, 2012 | 07:55 AM
98013HWR's Avatar
Check for ground on the wires going to the transistor
Old Aug 13, 2012 | 10:40 AM
If you are not getting a good ground to the resistor.
Attached Thumbnails Honda A/C Gurus needed!-misc.jpg
Old Aug 16, 2012 | 07:15 PM
Thanks for all your help, guys! I finally took it in today to the Honda dealership. FYI ... it was what they were calling the "transistor" (resistor). What beats me is, why didn't it work when I got a new one from the parts place and swapped it out? Maybe it wasn't a good ground? Idk. $160 for a cold A/C is a small price to pay in South Louisiana heat! Thanks again!
Old Aug 16, 2012 | 10:08 PM
  #17
In lower LA AC is a must,,,,been there before.
In the end, glad it it working and thanks for letting us know how it turned out.
omeezy
Jul 15, 2011 02:39 PM
white98accordex
Jun 10, 2008 02:21 PM
nafango2
Nov 29, 2007 10:02 AM
ckebottle
Nov 5, 2007 06:56 PM
00AccordLX5spd
Oct 23, 2007 07:36 PM
