Honda "Limp mode"
Old Apr 5, 2012 | 02:27 PM
argarcia86's Avatar
Default Honda "Limp mode"
My car right now is driving in limp mode cause I still havent replaced the crank position sensor, just curious about the limp mode.
How does limp mode make the car run, besides limiting going over 3000 rpm's.
Does it burn more gas? cause I feel like ill fill up the tank and it will be gone super fast.
I also have a leaking water pump, will this make the car lose power if the water pump is leaking?
Old Apr 5, 2012 | 02:35 PM
crispin's Avatar
It runs rich to help protect the motor.
You should fix it asap
Old Apr 5, 2012 | 10:31 PM
argarcia86's Avatar
yea trying to save up a little money to get it fixed, I dont think i can handle messing with the timing belt and all that.. even though I want to try, its my only transportation..
Old Apr 5, 2012 | 10:42 PM
crispin's Avatar
you will wish you did when that water pump seizes up, snapping your timing belt, and pushing your pistons into your valves.
I would not drive the car any further until it is repaired.
imsohungover
Mar 29, 2025 02:27 PM
matthewtorres2323
Mar 18, 2015 12:49 AM
hondavtec94
Feb 27, 2014 12:54 PM
thumper44
Sep 22, 2010 05:02 PM
ronjr8102
Aug 31, 2010 07:05 PM
