Hot air Drivers side vents
Old Jan 11, 2016 | 09:45 PM
lsmiddy's Avatar
Default Hot air Drivers side vents
I have a 2008 Honda Accord. Recently hot air is blowing out of drivers side A/C vents and cold air on passesgers side. The car does have a Dual A/C control. Does anyone know what is causing this?
Old Jan 11, 2016 | 09:52 PM
Honda had info. that an indicator of low refrigerant is when the left dashboard vent is warmer than the right one, with the A/C on. When that happens, the evaporator core isn't being flooded with enough liquid refrigerant, causing it to fully vaporize halfway through the core. As a result, the side of the core with some refrigerant (the right side) stays cold, while the side that's fully vaporized (the driver's duct) is warmer by about 20 degrees (or more in some cases).
Old Jan 11, 2016 | 09:54 PM
See article:
Attached Thumbnails Hot air Drivers side vents-ac-left-side-warmer-than-right-side.jpg
Old Jan 12, 2016 | 08:37 AM
lsmiddy's Avatar
Thank you. I will print this and take it to the shop with me and see.
shoot22
Feb 2, 2019 05:40 AM
Creepyjeeper
May 26, 2012 04:48 PM
sbi
May 19, 2012 08:38 PM
92Wahoo
May 18, 2009 07:35 PM
00AccordLX5spd
Feb 17, 2008 03:14 PM
