Hot key!
Old May 4, 2013 | 06:14 PM
elgart's Avatar
Default Hot key!
So here's the deal, I have a 1990 Accord lx automatic that is having trouble starting sometimes. When I start it the first time in the morning its fine, but if I am out and about turning the car off and on, sometimes I have to click the key on and off to get it to start. Now here's the weird part, usually when this happens the key feels hot when I take it out of the ignition switch! The car has a replacement ignition switch that is about two years old. Lately it has been getting worse.
Old May 4, 2013 | 06:31 PM
Warm key suggests ignition switch assy is failing (high resistance produces heat in switch).
Is starter "clicking" or just failing to do anything when problem arises.
Old May 4, 2013 | 07:34 PM
elgart's Avatar
I can hear a click and the radio and warning lights turn on, the switch is fairly new, could it be a bad connection somewhere?
Old May 4, 2013 | 08:46 PM
It only takes 15-30 mins to access the ignition switch. If it's burnt, you will know the switch is faulty.
csh217
Jun 17, 2014 05:53 PM
HateThisHonda
Jun 17, 2013 04:46 PM
corlyf
Sep 12, 2012 11:30 PM
rampcrawler
Jun 28, 2012 09:27 PM
Chri5tina
Jun 19, 2012 04:47 PM
