How to Clean Oil
Hi, im New here my english is not very well.
my Distributor is leak and i buy to change the O-Ring (30110-PC6-005).
but i want to clean the surfaces that get wet from the oil.
its ok to clean the Rubber hose with carburetor spray/degreaser ? and how to clean the metal surfaces , with carburetor spray/degreaser?
thx all.
(98' accord 2.0 LX)
thx all.
(98' accord 2.0 LX)
Well, I'd go with a "degreaser" instead of carb cleaner if I had a choice. If all I had was carb cleaner than I'd use it.
Clean as much as you can before removing the dist. Once it is out you should have more room to clean a bit more.
Put the new o-ring on, a light coat of engine oil on the new o-ring and see what you have from there.
jgregory01
Aug 15, 2011 05:39 PM
oldpitpony
Jul 6, 2009 03:04 PM
