How do I "clear" the Eng. malfunction light(check eng light)?
Old Oct 25, 2006 | 07:49 PM
62maxx's Avatar
Default How do I "clear" the Eng. malfunction light(check eng light)?
Hiya, all, got a 98 Accord LX 2.3 4cyl. While I was trying to find the fuse for the brake lights, I had the car running and I pulled the under engine fuse #5 labelled "stop" figuring this was for the "stop lamps" As I pulled it, I thought 20amps? anyway the fuse was fine and put it back. I then pulled the drivers side fuse #9 labelled Instrument panel,Back up lights. As I did this, the "chimes" started to sound,so I put it back in. It was OK also. But then the green D4 Drive indicator light began flashing on & off and the eng malfunction light came on. I shut the car down for a bit, the D4 Green light "reset" itself but the malfunction light is constantlly on.... any help on how to reset this light? Thanks very much!!!!! Great Site!!!!!
Old Oct 26, 2006 | 01:04 PM
deserthonda's Avatar
Default RE: How do I "clear" the Eng. malfunction light(check eng light)?
if you do not have a scan tool,,,,,,
On the passenger side under dash fuse box remove fuse # 13 , 7.5 amps, clock/ back up for about 20-25 seconds ,make sure key is off..
that will reset the ecm
ghost rider
Jun 5, 2011 08:35 PM
partsman1
Apr 17, 2009 08:46 AM
1lowcaprice
Feb 9, 2009 03:26 PM
CRVtoAccord
Jul 3, 2007 01:09 PM
accordn2me
Dec 6, 2005 01:30 PM
