How do I lock and unlock glove box?
Old May 25, 2020 | 09:19 AM
Muertex's Avatar
Default How do I lock and unlock glove box?
Hi, I just acquired a 2005 accord to replace my wrecked 2011 odyssey that I had the same issue with. I don’t know how to lock or unlock the glovebox.
I see there is a key slot, but mine only goes in partially and when I turn the key it doesn’t lock the glove box it’s just stuck in unlock position.
I couldn’t find anything in the operators manual.
Old May 25, 2020 | 10:56 AM
Seanjordan20's Avatar
That's how you lock it. The key doesn't go all the way in. Is there something wrong with the alignment of the glove box. Try pushing it up while trying to turn the key
Old May 25, 2020 | 11:02 AM
Muertex's Avatar
Tried that with no luck. I had the same issue with my odyssey but I thought maybe the key and ignition wasn’t the original but now I know these are original keys and locks and it’s the same thing with this glove box. The key just won’t turn.
I guess I’ll keep banging on it hoping it works some day.
Old May 25, 2020 | 11:16 AM
I'll have to try mine. I have used it since I drove it off the lot
Old May 25, 2020 | 02:18 PM
Mine work as described with no issues. Could it be the compartment was replaced?
Old May 25, 2020 | 06:07 PM
Try spraying some WD-40 into the glovebox lock to unbind the lock mechanism?
Old Jun 3, 2025 | 08:22 AM
7dctrans's Avatar
Default I have same
Help I have same problem???
Old Jun 3, 2025 | 07:55 PM
If your key doesn't lock it then it's not the correct key and the box has been replaced. It's a simple mechanism. Original key goes in partially which is how it's suppose to be and then you turn. That's it
rodrigo7x
Aug 31, 2018 05:43 PM
millmeg
Mar 22, 2015 03:09 PM
darkgreen18290
Oct 1, 2012 07:14 PM
rhinogolf
Dec 13, 2010 04:26 AM
91boz
Dec 19, 2006 02:12 PM
