aftermarket central power lock problem
Old Sep 30, 2012 | 02:59 AM
darkgreen18290's Avatar
Default aftermarket central power lock problem
Have problem with my aftermarket central power lock, the unlock is acting weird, when I press the unlock key on the remote or pull the unlock **** it will immediately lock itself, it happen only for the first 4-5 times you try to unlock, but after several try it will operate normal. What should I check first?
• Power lock in driver side door
• Power lock module
• Remote alarm module
I recently reset the remote alarm module by the module itself but no effect.
Thanks for the advice.
Old Sep 30, 2012 | 07:09 AM
Does the same happen if you use the key to unlock the door?
Old Sep 30, 2012 | 11:17 PM
yes when i flip the key to unlock then its immediately lock, what i'm doing i stay the key to unlock position longer for about 2-3 seconds, however the lock function is normal.
so now i'm using the remote to lock from outside, then key to unlock.
Old Oct 1, 2012 | 07:14 PM
With that bit of info, sounding like the door lock actuator....not sure if the 6th gens are set up like the 5th or not. Redbull has a very nice post (found in the "Common DIY Threads" sticky at the top) on the common issue with the 5th gens......good luck
HateThisHonda
Sep 19, 2013 09:45 AM
tnci
Jun 21, 2011 06:18 AM
jgw
May 25, 2011 08:41 AM
rajbsn
Aug 9, 2007 07:39 AM
