How do I make my brake light more sensitive?
Hi there....
when i press down on the brake.. the light are not that sensitive to light up.. I have to press all the way down for it to go on.
since changing the brakes and rotor..this happen.
usually it will light up when i applied the brake half way.. but now it have to go all the way down.......
is there a setting for this???
thank you.....
thank you.....
The lights are controlled by a little switch up above the pivot of the brake pedal. You'll have to stick your head down at the floor & maybe(?) push some trim peices out of the way.
Sounds like that switch is out-of-position, or screwed up, or maybe it's bracket is bent. Have to get down there & look at it to see what's up.
ORIGINAL: kennilope
where does the switch located it?
on front brake???
pax or driver side???
on front brake???
OK.. sorry for that stupid question.
i just realized i read it wrong.. and as i read the reply i had a good laugh at myself for how stupid i have been asking that dumb question
I though he say the switch is in the brake pad somewhere in there...
LMAO..... i need some drugs...
