how do you check engine codes on a 95 accord ex
Old Jul 15, 2009 | 05:57 PM
KiCKiN_aX
Default how do you check engine codes on a 95 accord ex
just got a 95 accord ex its got alot of lights lit up after i start it up , my question is where is the odb plug to check codes or is there another way to read codes thanks in advance
Old Jul 15, 2009 | 07:05 PM
Your car is likely only OBD1 compatible. To check codes, you short the service check connector (blue 2-wire under glove box possibly plugged into a plastic holder pinned under the dash) and read the Check Engine Light flashes.
See following link for more details and instruction.
http://www.tegger.com/hondafaq/faq_ii.html#retrieve
Old Jul 15, 2009 | 08:05 PM
Here is a good set of instructions on what to do.
http://www.dhost.info/accordinfo/howto/cel.html
Count the check engine light for ECU codes, D4 light for transmission codes.
dacecil
Jun 21, 2012 06:27 PM
VI009DZ
Nov 6, 2011 09:48 PM
PiksPal
Dec 31, 2010 10:03 AM
DadofFour
Oct 10, 2007 06:34 AM
saad180
Jan 3, 2007 10:45 PM
