how do you check engine codes on a 95 accord ex
Your car is likely only OBD1 compatible. To check codes, you short the service check connector (blue 2-wire under glove box possibly plugged into a plastic holder pinned under the dash) and read the Check Engine Light flashes.
See following link for more details and instruction.
http://www.tegger.com/hondafaq/faq_ii.html#retrieve
Here is a good set of instructions on what to do.
http://www.dhost.info/accordinfo/howto/cel.html
Count the check engine light for ECU codes, D4 light for transmission codes.
PiksPal
Dec 31, 2010 10:03 AM
