how to get codes on a 92 accord LX
Old Oct 29, 2009 | 04:10 PM
ACCORDingtothestreets's Avatar
Default how to get codes on a 92 accord LX
how and where do i short the system to check the codes for the check engine light on a 1992 accord lx 4 door 5 speed
Old Oct 29, 2009 | 05:57 PM
Use a thin paper clip or wire to short blue two pin connector. Turn key to II position. Count check engine light flashes. Long blink =10, short blink =1.
Attached Thumbnails how to get codes on a 92 accord LX-untitled.jpg   how to get codes on a 92 accord LX-untitled1.jpg
Old Oct 29, 2009 | 07:37 PM
ok thank you so much i got the code its 6 short flashes then a pause then 7 quick flashes do you know what this means thanks again this forum is such a big help thanks to you
Old Oct 30, 2009 | 01:53 AM
6 - Engine Coolant Temperature Sensor
Check wiring and resistance on the sensor. Drain coolant, replace sensor if it is out of spec.
7 - Throttle position sensor.
Check wiring is secure. Also test the sensor.
The TPS is technically not replaceable, and a Honda Dealership will only sell you the entire throttle body which will be expensive. Junkyards are good sources for cheap parts. There are aftermarket sensors out there that you can install. You will have to adjust the sensor so the idle position properly.
See my recent post on the Online Manuals link in the DIY section to get a look at the 91 accord shop manual. It will have diagnostic procedures with pictures for you.
PhillyTurboSix
Jun 1, 2008 11:10 PM
isenegger
Jan 19, 2008 08:15 AM
larrysnach
Mar 11, 2006 10:48 PM
megaman
Mar 10, 2006 01:13 AM
rcm800
Feb 17, 2006 02:56 PM
