How to Locate exhaust leak?
Have a difficult exhaust leak '87 carb'd accord.
How about adding a small amount of 2 cycle oil into the carb while runnng and partially covering the tail pipe to force the smoke out the leak?
Other spray available?
actually if you get a friend to plug up the mufflet tail pipe while car is running, you should have no problem locating the leak,, you will hear the noise .........that's what i have always done and always found the leak
Same here. Wad up an old rag & press it over the tailpipe. The leak will get louder & then it's easier to find it. I've never had to resort to putting oil in the engine.
ChicagoBob123
Sep 19, 2010 06:44 PM
ZMan3000
May 15, 2008 03:10 PM
