How to Locate exhaust leak?
Old Aug 23, 2006 | 01:32 AM
Alekat's Avatar
Default How to Locate exhaust leak?
Have a difficult exhaust leak '87 carb'd accord.
How about adding a small amount of 2 cycle oil into the carb while runnng and partially covering the tail pipe to force the smoke out the leak?
Other spray available?
Old Aug 23, 2006 | 04:37 AM
deserthonda's Avatar
Default RE: How to Locate exhaust leak?
actually if you get a friend to plug up the mufflet tail pipe while car is running, you should have no problem locating the leak,, you will hear the noise .........that's what i have always done and always found the leak
Old Aug 23, 2006 | 09:43 AM
Same here. Wad up an old rag & press it over the tailpipe. The leak will get louder & then it's easier to find it. I've never had to resort to putting oil in the engine.
Old Aug 23, 2006 | 12:27 PM
Alekat's Avatar
Thanks guys!
Looks like its coming from inside the S/S flex weave where the solid exhaust enters, (a couple of feet ahead of the cat).
ChicagoBob123
Sep 19, 2010 06:44 PM
brickballer
Nov 25, 2009 10:23 AM
2fargone
Jun 19, 2008 03:41 PM
illomatic
Mar 24, 2007 07:39 PM
