how many quartz of tranny fluid do i need?
Old Mar 4, 2008 | 07:45 PM
jose310's Avatar
Default how many quartz of tranny fluid do i need?
well im getting my tranny rebuild and i was wondering how many quartz does it need. its a 1994 lx auto 204XXX
Old Mar 4, 2008 | 10:32 PM
Default RE: how many quartz of tranny fluid do i need?
I don't know if it's all the same, but for a '98 I had it was like this:
The total (dry fill)was 6.6 quarts.
Drain & fill was 2.6 quarts.
It may not be the same all years, but it'll give you an idea of how much stays behind when you driain it.
Old Mar 5, 2008 | 03:53 PM
19Accord97
Ask your dealership. You'll be there anyways getting the fluid.
ONLY USE HONDA TRANNY FLUID
Old Mar 5, 2008 | 06:02 PM
hondadude's Avatar
I think the last full rebuild I did used 7.5 quarts
Good idea to go ahead and put a quart into the TC before install, so it doesn't start up dry.
Then after the trans is bolted up and axles are in you can put in 4 quarts, thats enough to start it up, shift thru reverse and drive, holding the brake of course, then shut it off and recheck the fluid level.
02whitemaximase
Oct 3, 2012 12:54 PM
Mott
Dec 4, 2010 10:12 PM
wcoyote2006
Nov 1, 2010 12:53 AM
jasonan
Aug 28, 2009 11:26 PM
mike87
Jul 13, 2009 10:16 AM
