How much ATF after engine replacement?
Old Oct 9, 2014 | 09:54 PM
anim8onme's Avatar
Default How much ATF after engine replacement?
Me and my father (mostly him) just replaced the f22b1 on my 94 accord and I am wondering how many litres of transmission fluid I will need?
Old Oct 10, 2014 | 07:55 AM
moey's Avatar
Did you drain the torque convertor? If you did not I would suggest start with 3 quarts and then go from there. Let it run for a couple minutes then turn it off and recheck.
If you did drain the torque convertor youll have to add more I would only suggest a quart more then start the engine and recheck. Dont add the full amount as it does not get pumped into the torque convertor until the transmission spins so youll overfill the main part of the transmission I would suspect. At least that is what I did when my torque convertor had a unknown amount.
Old Oct 11, 2014 | 09:11 PM
anim8onme's Avatar
Thanks, ended up using 4L.
Blastingas10
Dec 21, 2014 06:54 AM
TXAccord2012
Nov 11, 2014 12:37 PM
jeremu
Mar 6, 2012 01:24 PM
moey
May 22, 2011 10:43 AM
NICK63
Nov 2, 2009 11:57 AM
