How much is too much oil?
Old Jan 30, 2018 | 07:31 PM
rockhoundrob's Avatar
Default How much is too much oil?
I put oil in my daughter's car but it turns out I put a little too much.
I put about 1/3 quart too much (about 1/4 inch over the max mark). Is this bad? Should I drain the oil a little so it is at the top of the mark on the dipstick?
If it not a big deal, then how much is too much, where I would need to drain the oil a bit?
Old Jan 30, 2018 | 09:31 PM
I think you will be fine at that level. If the level gets too high, the crankshaft can start whisking the oil. I don't think you'll be near that level at 1/4 inch above the full mark.
Old Feb 3, 2018 | 08:22 PM
UhOh's Avatar
In past I've had change places overfill my 4cyl Accord engines by about 3/4" on the dip stick. No bubbles nor excessive burning; no problem.
RobinsonRicer
Dec 22, 2013 08:42 AM
Sadus
Sep 6, 2011 11:29 PM
NICK63
Nov 2, 2009 11:57 AM
bambooyou
Sep 16, 2008 11:59 AM
joninja
Dec 1, 2007 12:13 PM
