how to remove a 3m double-sided tape?
Old Aug 13, 2011 | 11:05 PM
gelboy's Avatar
Default how to remove a 3m double-sided tape?
I bought an aftermarket fuel lid cover on my 09 accord. unfortunately I didnt put it right, I want to redo it again. I tried to remove it but it was so sticky. my questions are:
what tool do I need to use to remove it?
If I removed it already can I buy another 3m tap so I can stick it back again to the fuel lid?
pardon my english. this is also my first post. thanks in advance
Old Aug 13, 2011 | 11:17 PM
gelboy's Avatar
sorry I put this in the wrong forum. Idk how to move this to the general discussion forum
Old Aug 14, 2011 | 01:31 AM
Moved it for you..Welcome!
Old Aug 14, 2011 | 03:02 AM
engtaz's Avatar
Almost A Senior Member
Adhesive remover from auto stores or Walmart should work.
Old Aug 14, 2011 | 10:00 AM
bigpat's Avatar
Goof Off adhesive remover works very well.
Old Aug 14, 2011 | 10:45 AM
I like 3M adhesive remover which I was able to pick up at Walmart. It is in the auto section and can have a black or white label. The one I bought was a white label.
walmart.com/ip/3M-12-oz-Adhesive-Remover/17056835
Old Aug 14, 2011 | 12:22 PM
Then for new tape, 3m would be the brand of tape I would look for....you'll have to figure out width and thickness. Then go to a good parts store or if there is a paint store near by then go there, they should have or be able to get you what you will need.
Old Aug 15, 2011 | 08:15 PM
gelboy's Avatar
thanks a lot I appreciate it
justinit
Sep 24, 2009 04:56 PM
rubenm199253
Jul 13, 2009 08:17 AM
Sled14
Oct 31, 2008 06:41 PM
DANIELYSE9
Feb 13, 2008 10:33 AM
dan_o_89_rs
Aug 23, 2007 03:14 PM
