How to Remove Oil Pressure Switch
Old 03-27-2012, 08:46 PM
brandon0409's Avatar
Update:
Okay. So i went to the local parts store and bought a specialty socket to remove the oil pressure switch. Long story short, none of the stores sell a specialty socket that actually fits my switch. They were all to big. So I found a regular socket that happened to fit and it came right off.
Now to my question:
When I tried to reconnect the cable to the sensor, it won't stay on. It slips on then just slides right back off.
Is there something wrong with the connector or do I just need to push it on harder?
Or, can I just get a new wire and connection from the parts store?
Has anyone else had this problem?
Old 03-27-2012, 10:39 PM
Was the new pressure switch the same socket size as the old one? If you have the old one, see if you can plug the electrical connector into it.
Old 03-28-2012, 06:33 AM
Hmm. Good idea. Yes it's the exact same other than a small cosmetic difference. But all of the connections are identical. I'll try that today.
Old 03-29-2012, 11:19 AM
Okay. I tried to reconnect the cable to the old oil pressure switch but I have the same problem as when I try to connect it to the new one. It just slides right back off.
I've removed all of the Rubber coating that was left on the cable, thinking that was hindering things.
I might just stop by the Honda parts center at my local dealer and see what they say.
Old 03-30-2012, 05:36 PM
The female end (wire side) of the bullet connector might need a "gentle" squeeze with a pair of pliers....
Old 03-31-2012, 11:22 AM
Yes. I was doing all of this when it was dark. I was thinking that there was some complex splicing going on it was literally just a single spliced female connection.
So the next day in the day light, when I went out and saw that it was just a simple job of crimping the old connection around the new switch.
The original reason that I didn't know was that there was a plastic casing around the connection. But once I removed that I saw what needed to be done.
So all is good and it is finished. I had to wrap it in electrical tape. I hope that will be sufficient.
Wrapped Oil Pressure Switch
  #17
Old 03-31-2012, 12:20 PM
That looks good. The next time you go to change the oil, I would take a look at the electrical tape to make sure it isn't melting or showing signs of burning just to be safe.
  #18
Old 04-01-2012, 08:53 AM
Is there something else that I SHOULD put on the switch instead of the tape?
  #19
Old 04-01-2012, 10:39 AM
That is what I used. The engine gets hot while running. I was just suggesting it as a precaution.
usedcarman
02-22-2024 03:48 AM
HBRobTC
07-20-2011 06:50 PM
swells244
07-09-2010 08:28 PM
freezerman
07-03-2009 09:40 PM
kcobra
08-07-2006 10:39 PM
Quick Reply: How to Remove Oil Pressure Switch
