how to remove timing belt top cover
Old Jan 3, 2011 | 11:02 PM
darkgreen18290's Avatar
Default how to remove timing belt top cover
Hi guys, just want to ask if you need to remove valve cover to remove the timing belt top cover?
Yesterday I want to check my timing belt but its giving me hard time to remove the cover, I already manage to remove the two bolts of the cover but it’s not coming out. Did I missed something…
Thanks.
Old Jan 3, 2011 | 11:10 PM
I think you need to remove the valve cover.
Old Jan 4, 2011 | 11:55 AM
You don't have to completely remove, but all retaining nuts must be removed and valve cover lifted slightly to allow upper TB cover to clear from under the valve cover.
Old Jan 5, 2011 | 01:27 AM
alright, got it! i will try once again this weekend.
thanks much
Old Jan 5, 2011 | 05:47 AM
A cautionary comment. Be very careful when working near the open upper timing belt cover. If you drop anything into the timing belt cavity, there is good possibility of damage if object is not removed. Removal is a big job requiring removal of cranshaft pulley and lower timing belt cover.
Old Jan 6, 2011 | 02:51 AM
i'll take note on that!, thanks
Old Jan 6, 2011 | 10:13 PM
bigdawg74's Avatar
Not meaning to 'jack this thread, but my '91 has 138k miles on it. Unknown if TB has been replaced by previous owner(s). If I was to pop off the valve cover/TB cover and look at the belt, what would be a good indicator of if it has (or has not) been changed? Also, once the VC has been removed, does one need to replace the gasket? Thanks, guys....
Old Jan 7, 2011 | 06:20 AM
There are no reliable wear indicators. Replaced belts don't look substantially different than new belts usually. If it's obviously worn, then don't delay replacement. If it looks pristine, then you'll need to replace anyway because you don't know that it's ever been replaced. Consequences of not replacing are severe; certain valve damage and potential to damage pistons also.
Only way to know would be to contact the previous owner and ask if TB has been replaced.
Old Jan 7, 2011 | 06:51 AM
x2
An old belt will look quite good until maybe a few weeks before it breaks. What you DO want to look for is cracks at the base of each tooth on the belt. Problem is, those cracks don't necessarily appear very long before you have trouble.
Belts don't usually break by the belt coming apart. What happens more often is teeth will come off causing the cam to lose synch.
Old Jan 7, 2011 | 09:17 AM
I've also noticed on 2nd TB change where tensioner bearing was not replaced at 1st TB change that bearing grease was marginal (dryed out and bearing was slightly "rough"). It's doubtful the bearing would have survived to a 3rd TB. So, replacing the tensioner idler (bearing) is highly recommended also. They are not expensive.
Failure of beaing would lead shortly to failure of the TB.
