How to use a volt/multimeter?
Old Sep 12, 2010 | 10:27 PM
Touge07's Avatar
Default How to use a volt/multimeter?
Ok guys i know nothing about wiring or electricity so bear w me. I have and overheating car and i bought a multimeter to check for 12 volts(thanks to a member here) on the cables to the radiator fans, but the meter has a **** in the middle and a bunch of settings to use, like ohms dc acv all kinds of crap. If you need to see it they have it at harborfreight.com, its the red one thats 3.99, i also bought a 6/12volt screwdriver looking thing that lights up, should i use that instead?, thanks and sorry for the confusion
Old Sep 13, 2010 | 01:43 AM
Whenever you measure voltage with a battery, it is direct current (DC). The number you want is 20, because that means you can read in the 2-20 volt range.
Set the volt meter to DCV 20, and touch the black lead to the - battery terminal, and the red to the + battery terminal. The meter should read around 12 volts.
Old Sep 13, 2010 | 08:02 AM
Measuring the battery like that just shows you how the meter displays the measurement. The real thing is for you to now put the meter probes on the 2 wires that connect to the radiator fan to see whether they are giving power to the fan.
Old Sep 13, 2010 | 03:33 PM
Touge07's Avatar
Thanks alot guys, i will be doing this today and will updating later!
snifly one
Feb 2, 2011 05:53 PM
MROOKIAN
Jul 26, 2010 04:08 PM
Tony1M
Mar 7, 2009 08:00 PM
loki
Jan 20, 2008 12:01 AM
steviebix
Aug 17, 2007 12:14 AM
