HUge rock ripped hole oil pan
Old Apr 30, 2008 | 05:19 AM
2002haccord's Avatar
Default HUge rock ripped hole oil pan
so today while driving to work following a pickup a huge rock appeared soon as pickup passed and had no time to swerve out the way wanted to know well im assuming the oil pan got torn a hole but not sure is there anything else that would be leeking that much oil and its motor oil it aint red
Old Apr 30, 2008 | 07:23 AM
Default RE: HUge rock ripped hole oil pan
All I can say is to put it on a hoist today and inspect the damage...tell us what it ends up being!
Old Apr 30, 2008 | 08:03 AM
Oil pan is the obvious target, being down on the bottom of the engine. You gotta look at it. A hit like that will leave a mark so there should be no doubt about what needs to be replaced.
I assume engine oil is going low because of it all leaking out?
ATF is reddish, but not real strong bright red.
Anti-freeze smells so much different than oil so you'd know that.
Power steering fluid is up there too, there'sa cooler that looks like a loop of tube in front of the radiator.
AC refrigerant is under pressure & it leaks out like a cloud of vapor.
Old Apr 30, 2008 | 11:52 AM
so far what looks its oil pan its crushed at a corner and i can see a hole where it got puncture. thats what you get for living in chicago lots of potholes
Old Apr 30, 2008 | 11:56 AM
finch13's Avatar
My friend cracked open his A4 oil pan and I welded it for him. It's made out of aluminum so you'll have to find someone who can weld that, it might be cheaper than replacing the pan, not sure.
Old Apr 30, 2008 | 03:13 PM
just bought one from honda 115 autozone charged 90 but 6 day wait
ccookie66
Apr 12, 2019 04:43 PM
db12
Apr 26, 2012 12:07 PM
frost506
Jan 16, 2012 07:21 PM
greg9442
Oct 15, 2009 10:37 AM
dachoka
Jun 17, 2005 02:32 AM
