i feel heat while the heater is off
Old Feb 26, 2009 | 09:09 PM
nj_accord97's Avatar
Unhappy i feel heat while the heater is off
hi guys last few day i notice something never happend in my 97 accord v6 before.
i feel heat inside the car while im driving while the heater is off..i tempture for the heat is low specialy in winter im just wondering what can cost that to happend.....??????
need help plz.....i dont want to feel heat inside the car when the summer time come
Old Feb 27, 2009 | 06:44 AM
Have someone work the temperature control while you watch the valve operate on the heater hose (in the engine compartment). If the car was 1998, it would need to be turned on but not sure for 97.
Possible that a cable is broken or disconnected, so the control doesn't actually open & close the actual heater valve.
Old Feb 27, 2009 | 07:05 AM
I know with every mid 90s honda i have ever driven including both my 97 and 95 accord if you have the blower set to 0, but the temperature **** still turned all the way up hot air will still come out the vents, you just have to turn the temperature **** more in the middle and it shouldn't be hot anymore.
Old Feb 27, 2009 | 07:19 AM
Are we talking about the temperature control or the fan control?
If the temperature control is hot but the fan control is OFF, then you SHOULD feel heat because the car's motion will push air thru the ventilation system.
If the TEMPERATURE control is turned down to COLD, then your problem sounds like a broken or disconnected control cable out to the heater valve.
Old Feb 27, 2009 | 02:08 PM
If you turn on the air recirculation, then no outside air will be pushed through the ventilation system.
Old Mar 2, 2009 | 12:19 PM
htekken's Avatar
^yes i do that too whenever i want the unwanted air to stop.
Old Mar 2, 2009 | 12:35 PM
deserthonda's Avatar
make sure that the heater **** is not broken,,
tomd
Mar 9, 2013 06:35 PM
skijour
Aug 15, 2012 08:31 PM
mikebel
Oct 11, 2011 01:43 AM
Cessna172
Nov 5, 2010 01:22 PM
IWL BCNU
Nov 21, 2008 07:12 AM
