i have a 95 honda accord dropped & shaved doors
Old Sep 6, 2010 | 09:28 PM
pderdadon's Avatar
Question i have a 95 honda accord dropped & shaved doors
my issue is the car gets wet when i park on a hill when facing up. my mechanic told me he have to take my interior out to fix it. how do i fix it w/o having to do that.
Old Sep 6, 2010 | 10:25 PM
g22cd5's Avatar
Supper Moderator
you need to find out where is leaking 1st...more info would help
Old Sep 7, 2010 | 01:24 PM
howheather's Avatar
Sounds to me like it is the A/C evaporator leaking. Does is make sloshing sounds when you make sharp left or right turns? How about a funky smell?
If that's the case, you're going to need to unplug the evaporator to let it drain. Use an old wire coat hanger - locate the evaporator drain hose on the interior fire wall of the front passenger floorboard. Remove the hose from the evaporator (give a gentle tug), poke the coat hanger into the evaporator - SUPER gently, then as water starts to drain, shove the hose back on quickly.
After this, you'll need to remove the seats, center console and carpet. You'll need to pine-sol and shop vac the floorboard, steam clean or scrub with Clorox colorsafe bleach the carpet and then reinstall.
It's a crap job, took me about 7 hours, but it was well worth it.
Old Sep 7, 2010 | 07:24 PM
If it is from the evap (pass side), you can just "rig" up something on the shop vac and suck out the water and junk from the drain tube. Less likely to poke a hole in something.....still have to get the carpet and that clean.
If it is coming from somewhere else?...a whole new story.
daver1100
May 30, 2014 08:00 AM
Amtrak288
Aug 31, 2011 08:18 PM
hambone3535
Nov 21, 2010 12:12 AM
josher94
Jul 6, 2007 10:45 AM
accordlowered04
Jul 4, 2005 12:37 AM
