I need some A/C help
Old Jul 8, 2006 | 03:15 PM
Brian's Avatar
Default I need some A/C help
I tried posting this on another Honda forum but didn't get any replys. I have a 2001 Civic DX, air conditioning stopped working a couple of days ago. When I first started looking I found a 20 A fuse burnt out for the condensor fan. Fan now works but still no a/c. Controls seem to be working ok, condensor fan comes on once the a/c switch is turned on and the temp control works but not cold air. I removed the guard in the wheel opening and the clutch turns freely but doesn't engage. I tried swapping the relays in the engine compartment fuse box but no luck there either. Any suggestions as what to check next. I'm cookin any help would be appreciated.
Brian
Old Jul 8, 2006 | 03:32 PM
sir_nasty's Avatar
Default RE: I need some A/C help
is your condernsor fan coming on? The main issue I've seen in here is either the second fan for the A/C doesn't come on or your a/c needs recharged. Start the car, pop the hood and turn on the a/c, verify that the right hand fan (as you're facing the car) comes on. If your fan is coming on have you checked for a/c leaks and to make sure that it's charged?
Old Jul 8, 2006 | 03:36 PM
Chiovnidca's Avatar
Does the compressor clutch wire have voltage?
Old Jul 8, 2006 | 06:49 PM
lightshow's Avatar
yea if both fans are coming on when you turn the a/c on then it might be your compressor clutch fuse that is blown. i dont have an explanation for why it would have blown though, which would be the biggest problem
Old Jul 8, 2006 | 07:11 PM
Brian's Avatar
Ok, back from a few checks, both fans are working, I tested the blue/red stripe running down to a plug just above the pump that has voltage. This wire runs down on top of the pump but because things are so cramped up I can't follow it without taking the power steering pump and altenator off. I can see a ground plus a black and a red wire(with fusable link) sitting on top of the pump. I checked for voltage here: the black wire has voltage but the red wire has none.
Old Jul 8, 2006 | 07:26 PM
Chiovnidca's Avatar
ORIGINAL: Brian
The blu/red is the one your after, it should plug into a red wire at the compressor. If they have 12 volts, the thermal protector may have popped. You'll have to dig a little deeper.
Old Jul 8, 2006 | 09:20 PM
Brian's Avatar
No voltage on the red wire. I found a pic of the culprit here in case anyone else is having a similar problem. Item # 5
Old Jul 10, 2006 | 09:51 AM
Brian's Avatar
Is it ok to assume that if there isn't voltage at the red wire, then the thermal protector opened????
Old Jul 17, 2006 | 10:31 PM
Brian's Avatar
Update, a/c is now working, it was the thermal protector set, thanks to all who answered my post, hope this benefits others
pacifica_kid
Nov 27, 2006 02:30 PM
19accord92
Apr 15, 2006 08:50 PM
HondaLawgik
Feb 8, 2006 02:21 PM
blazedg
Jul 5, 2005 07:52 PM
blacktopracer
May 11, 2005 10:11 PM
