iacv cleaning
Old Nov 29, 2011 | 11:52 PM
tanhanson94's Avatar
Default iacv cleaning
my idle air control valve needs to be cleaned, i was wondering if someone could give me step by step directions on how to remove it so i dont screw anyhing up, thanks
Old Nov 30, 2011 | 12:33 AM
mishakol129's Avatar
This is the way I did it.
Things needed:
-Paper towels or shop towel for the coolant lines if they leak out the ends
-Brake or carberator cleaner
1. Take off the coolant hoses for the IACV. If your coolant hoses for the IACV are too hard to take off due to age or wear, then you're going to have to take off the FTIV first and then you'll be able to take the coolant hoses off of the IACV.
2. Just take it off, inspect how much gunk is on the screen and then spray and pray. Clean off the screen as best as can be.
3. Re-assemble like you dis-assembled it.
Old Dec 1, 2011 | 07:07 AM
Dakota21601's Avatar
Anyone have a diagram for a 98 2.3L on where the IACV is or just a good explanation? My guess is the piece attached directly under the intake port on the TB?
Old Dec 1, 2011 | 09:53 AM
look towards the firewall, behind the manifold and around by the intake.
Old Dec 1, 2011 | 11:58 AM
Check DIY forum for guidance on IACV cleaning.
Use vise grips w/ hose liners on the grip face to pinch the hoses either side of the IACV. This will allow removal w/o significant loss of coolant.
Clean both sides of throttle plate and throttle bore around plate also.
Remus77
Mar 1, 2015 12:51 PM
slickgeek
Jan 28, 2015 01:56 PM
jfidelh
Aug 30, 2011 07:24 AM
Diorel
Aug 21, 2011 12:49 AM
93_DailyDriver
Jun 11, 2011 05:40 PM
