idle drops from intermittenly
Old Mar 15, 2008 | 03:11 PM
sinister1
Default idle drops from intermittenly
Hi,
Posted before on this topic. 95 accord vtech codes are clear high milage 250k running well.
At idle when stoped in gear on and off the idle will drop about 100 rpms havent put it on a tach just using the one in the dash. When the idle drops the car runs rough meaing you can feel a shake. Any advise appreciated.
Lee
Old Mar 15, 2008 | 03:57 PM
sir_nasty's Avatar
Default RE: idle drops from intermittenly
Any other issues with it under acceleration? what's the last tune-up work you've done to it and how long ago?
Old Mar 15, 2008 | 05:55 PM
hondadude's Avatar
pull loose the IACV and use some Berrymans B-12 to blast out all the soot from the screen.
Then while you have the Berrymans in your hand, grab up a softbristle brush [wifes toothbrush works great] and scrub out the ring of crud around the throttle plate.
I hold the throttle open by using a long screw driver under the cable and bracing it on the top of the intake.
Old Mar 17, 2008 | 06:55 AM
fatboy77's Avatar
Ok, its 4:30 in the morning, gettin up for work and Im still [sm=sleeping.gif] and cant remember what the IACV are.
Old Mar 17, 2008 | 01:54 PM
The IACV is to the behind and right of the throttle body. Its held in by two bolts, has two coolant lines, and a three pin plug going to it.
Old Mar 18, 2008 | 05:45 AM
sinister1
Default RE: idle drops intermittenly
up date, cleaned the throttle plate and body, sorry no B12 in ny good ole gumout. The body looked clean, the plate was dirty looks already cleaned the IAC. Lasted for about a day now back to idle dropping and rough. Any further ideas appreciated.
Lee
GhengisFong
Jun 29, 2014 01:46 PM
JEQuien
Oct 15, 2012 04:23 PM
gjm
Jun 17, 2011 10:24 PM
swhitney11
Oct 14, 2008 08:45 PM
jose310
Jan 27, 2008 10:01 PM
