Idle Hangs when shifting - Choppy Clutch Engagement - 5sp manual - F23A1
Old Apr 4, 2013 | 09:17 PM
j894's Avatar
I was almost thinking the same thing, that the IACV is somehow malfunctioning in a subtle way.
Usually the junk yards around here are cleaned out of every usable part for 6th generation accords. I'm gonna keep checking though.
I just had a new ebay IACV but it was aftermarket and brand new, it had intermittent issues with idle surge (my stock old one didn't) so I returned it. It was hard to tell if it really made a difference really because of its own issues.
I cant see spending the $$ on an OEM honda one without knowing it will solve the problem.
Will report back when I find an OEM IACV
I appreciate the help.
Old Apr 18, 2013 | 05:59 PM
j894's Avatar
Update:
I found a used IACV in a junk yard. I cleaned it out really well and installed it. The IACV seems to respond quicker idle does seem to come down slightly faster now especially when cold. If I floor it in 1st, it doesn't hang nearly as bad when changing to 2nd,;however when the car warms up the idle seems to hang a little bit compared to when driving cold.
Upon unplugging it with the car running, the idle still bounces around a little so the base idle cannot be set. Again I can find no vacuum leaks I've been meaning to dig out my vacuum gauge to double check the idle vacuum, but I haven't found it yet.
The vacuum hose on I know of on the intake are:
Brake Booster (top)
IACV assist (on iacv running to lower intake)
Evap purge( on upper)
Cruise control (top of TB)
FPR (top of TB)
Transmission (top of TB - capped off b/c of manual transmission)
Am I missing any?
That said, the upper intake gasket and egr valve gaskets are only a few months old.
MGF 1996 Accord
Jul 13, 2015 11:48 AM
davntaz
Apr 11, 2015 09:10 PM
tr0910
May 1, 2014 04:05 PM
416communter
Apr 24, 2014 12:15 PM
az4438
Oct 28, 2011 08:30 PM
