Idle issue Accord 1992 carburetor
Old 02-28-2023, 10:20 AM
Accordcarb's Avatar
Default Idle issue Accord 1992 carburetor
I have an idling issue with my 1992 Accord
16v manual transmission 2.0l carburettor engine 110hp w/manual choke
Idling
The engine dies quickly at idle when both engine and weather is cold, at sub-zero temperatures the idle will chase approx. from 0 to 1100rpm back and forth. There will be a lot of smoke at freezing temperatures.
Normal idle a couple of years ago:
6800rpm when warm, and up to 2300rpm when cold, where it gradually regulates itself down
After 3-5 minutes of driving in the cold (as the car is starting to warm up) the idle speed up to typically 3-3.500 rpm and after another 5 mins when fully warm) it calms down to normal idle speed of approx. 6800 with only a bit poor idle. Right after the revs have calmed down and the car has warmed up, there is a risk that it may die at idle, this does not happen while driving. It has a rough start afterwards as it doesn't seem to get enough fuel, it usually starts while I hold the throttle/choke all the way down for a few seconds
While driving
The engine hesitates at low throttle while driving when it's cold outside, especially with a cold engine, noticeably better with a warm engine
Starting
The car is easy to start, but after this problem accured it requires more choke/throttle to do so
What has already been replaced without any improvement:
Replaced air filter
New spark plugs
Cleaned distributor cap
New fuel filter
Carburetor spray + cleaned most of the carburettor with compressed air + fuel system cleaner mixed in the tank
Replaced battery
Verified that the primary slow cutoff solenoid valve works, cleaned transition so that grounding works + blew inside the hole here
Functionally tested the air intake valve
Cleaned the PVC valve (the one on top of the engine block) + changed the hose to this one that were leaking
Replaced thermostat
Changed several vacuum hoses that were leaking
Replaced Fuel Cutoff relay (controls the fuel pump)
Any thoughts are appreciated
Fishmanmaximus
06-29-2013 07:17 AM
98accordpain
11-05-2012 11:31 AM
zedjr
11-01-2012 05:03 AM
skareb
03-31-2007 07:36 PM
Quick Reply: Idle issue Accord 1992 carburetor
