Idle RPM lag
Old Nov 18, 2013 | 06:10 PM
cc23's Avatar
Default Idle RPM lag
I have a 97 Accord SE, 2.2, automatic, a/c, 155k miles.
Any time a load is placed on the engine at idle (i.e. a/c compressor turns on, turn on headlights, cooling fan kicks on, etc.) the RPM drops considerably and takes several seconds to recover. If there are no loads placed on the engine at idle, it purrs along just fine.
I have looked through a few other posts and this doesn't sound like an RPM surge issue. The RPM is never higher than around 750 except for the first minute or two after starting the engine cold. In that case it idles around 1500 RPM, but settles down fairly quickly to normal without any surging.
Any ideas where I should start looking to fix this?
Thanks for the help!
Old Nov 18, 2013 | 06:31 PM
Look into cleaning the TB and also the IACV. There are some write ups on this; https://www.hondaaccordforum.com/for...threads-40780/
Found at the top of this section. After the cleaning I'd let the car "re-learn" idle.....info on how to is also in the same sticky.
Old Nov 19, 2013 | 08:34 PM
Look for the one about setting the "base idle". Do that & then have it re-learn the idle.
Old Jan 28, 2014 | 05:57 PM
cc23's Avatar
So I finally got some spare time to try to fix my idle issue... I followed the directions on this forum to clean the IACV, throttle body, and to reset the idle speed. No luck. The idle speed lags just as badly as it did before and my car idles at around 1500 RPM until it is warmed up.
Any other ideas before I spend a lot of $$ to replace the IACV? Is it possible there is some kind of lightweight lubricant that might keep the IACV from sticking? (Or is that a really bad idea...)
Thanks for the help.
Old Jan 28, 2014 | 07:11 PM
Roader's Avatar
Was the FITV cleaned/adjusted?
Old Jan 29, 2014 | 12:09 AM
cc23's Avatar
I read that '96 and newer Accords don't have FITVs. Is this bad info?
Old Jan 29, 2014 | 12:39 AM
The 98+ accords don't have a FITV. Your 96 has one bolted under the throttle body.
LSDisk0
May 12, 2014 06:38 PM
H55
Feb 19, 2009 10:29 PM
93AccordEx
Apr 7, 2008 11:40 PM
mikel6690
Jun 7, 2007 04:43 PM
Crusher
Jun 5, 2006 06:02 PM
