Idle too low under load?
Old Sep 30, 2008 | 07:50 AM
Gary L's Avatar
Default Idle too low under load?
'91 Accord wagon F22A6.
I just won the service manual but don't have it yet.
I removed and cleaned the fast idle and IAC units yesterday, screen was totally plugged and I thought for sure I licked the problem.
No Such Luck! As soon as I put it in gear the idle drops to under 500RPM and stays there until I give it pedal. When in N it idles perfect.
I need some advice troubleshooting and where else to look.
EGR seems to be functioning when I apply suction but I have not removed the 4 manifold plugs and cleaned them yet. I'm considering blocking the EGR completely as I don't have to pass any tests. Thoughts on this are appreciated.
Car runs fine once moving but just won't idle high enough when in gear and stopped.
Thank you
Gary L
Old Sep 30, 2008 | 09:51 PM
HondatechAV6's Avatar
Default RE: Idle too low under load?
idle is normally a little low on these. check the base idle screw adjustment if you know what your doing.
D3AD.P1X3L
Oct 24, 2014 10:55 AM
schoust
Jan 15, 2013 05:08 PM
Quaz
Dec 3, 2012 08:08 AM
moontruggy
Dec 12, 2007 04:33 PM
1991hondaaccord
Sep 16, 2007 07:49 AM
