Ignition key died!!!
Old Feb 24, 2008 | 09:30 AM
Jeff247's Avatar
Default Ignition key died!!!
I have a 2003 Honda Accord EX with 178K. This is my first problem!! The key will no longer lock, unlock, open trunk or sound panic. I have noticed it getting weaker over the last month. Almost like the battery dying. I see it has a 3v battery in it. I have another identical key that came with the car and another that will just open with key to lock. Is there anyway to fix the original key? I would still like a fully functional backup. Thanks in advance for your help.
Old Feb 24, 2008 | 09:38 AM
smaglik's Avatar
Default RE: Ignition key died!!!
did you check the owners manual? i would think there would be instructions for replacing hte battery in there.
Old Feb 24, 2008 | 10:59 AM
Jeff247's Avatar
Owners manual? Well I did so after your suggestion. Sure enough you can change the battery!!! Only in the EX. Takes a CR1616 battery. Hopefully Walmart has one. Thank you!!!
Old Feb 24, 2008 | 01:35 PM
smaglik's Avatar
np.
csh217
Jun 17, 2014 05:53 PM
faran
Feb 6, 2013 11:47 AM
corlyf
Sep 12, 2012 11:30 PM
brofrank
Jun 9, 2006 09:16 AM
brofrank
Feb 13, 2006 02:58 PM
