Ignition Key Stuck (95 Accord)
Old Apr 3, 2010 | 10:24 PM
austinman3214's Avatar
I have gotten this same exact problem, however, it has happened in my 7th gen. I just put in an amp and of course had the battery disconnected (got the radio lock code reminder, dont have the code though...) and had the shifter in position 1 while the engine was off. I went to put the car all back to together, everything seemed fine. I put the key in to test out my new system and got the stupid code (where can i find it?) but more importantly i could not take the key out.
Now i did some inspecting and found that when my removable shifter **** is OFF the key can release, but when screwed in correctly it cannot be released. there is a compressing mechanism that compresses when the **** is put on, i believe this is the problem but dont know where to go from there? ANY help would be greatly appreciated!
Old Aug 3, 2013 | 12:51 PM
Saritaas's Avatar
Default WD-40 + parking brake solved it for me
Thanks to everyone for the previous posts! They definitely helped me with troubleshooting.
I had the same problem--key wouldn't return to zero position. And while I did eventually get the key out, the car electronics stayed on. If I put the key back in and tried to start the car, the starter would engage, but the car wouldn't turn over.
I tried WD-40 and could then get the key in/out easily and start the car, but I still couldn't get the key to the zero position or turn off ALL of the electronics. Strangely, this time everything on the dash turned off--radio, ventilation, etc--but the open-door chime still sounded with the key out. Also, I could turn the ignition with the key just halfway in.
Dharwood had mentioned the "AT transmission shifter position" and the park switch perhaps being in a constant state of open, so I thought maybe changing the "park state" a little bit might help goose the indicator into knowing its true state.
I typically park the car without the parking brake engaged, despite a slight incline in our driveway. So to change it up, I started the car, reversed a foot, drove forward a foot, and engaged the parking brake before shifting the car to Park. This took some pressure off the transmission in the park state.
After doing that (set up by the WD-40) I was finally able to return the key to the zero position, turn the car completely off, and remove the key. Problem solved.
Thanks again everyone--your posts saved me a lot of grief and $100 in parts.
Tex_hooper
Sep 23, 2013 06:43 PM
cchandler
Jan 23, 2013 11:27 PM
AKcord
Oct 15, 2006 07:43 PM
brofrank
Jun 9, 2006 09:16 AM
brofrank
Feb 13, 2006 02:58 PM
