Immobilizer light blinking
Old Dec 19, 2022 | 07:23 PM
Rhambrick's Avatar
Default Immobilizer light blinking
I just replaced my pcm in my 09 Honda accord with the 2.4l in it. The pcm was ordered Vin specific after replacing it the check engine light went off codes went away for pcm internal malfunction but now I have the little green key that blinks when I try to start it I will start idle and shut off I don't know how to go about this as I have looked up way to reset it but none have worked is there any relays or anything that would make this do this or is there a way to bypass or reprogram the key if that even what it is I'm not a real experience gear head so I'm learning as I go but I don't have the money to put it in a shop labor prices are killer any help would be muxh appreciated.
Old Dec 19, 2022 | 10:13 PM
Some locksmiths can reprogram the immobilizer system for the keys/PCM, or you can use a device like this Autel to do it yourself.
Amazon Amazon
jimmylomax
Nov 16, 2019 11:11 PM
mannhalr
Jun 16, 2019 02:23 PM
RubberSalt
Jun 23, 2018 02:45 PM
jwolfe106
Apr 29, 2014 10:39 PM
BlueBessie
Sep 24, 2011 11:04 PM
