Info on HID conversion with highbeam
Old Mar 24, 2007 | 12:01 AM
95 exR's Avatar
Default Info on HID conversion with highbeam
I don't know if anyone here has had this problem, but I recently did, and this is what I did to fix it. When I finsihed putting in my highbeam HID's, I noticed when the DRL's were on, I actually had a highbeam on the driver side, and nothing on the passenger side. When I turned on the headlamps, I would have low and high beam on at the same time, and you couldn't turn off the highbeams. All you have to do with this, is pull the DRL fuse that is under the hood in the fuse panel on the passenger side. When I did that, I have low beam HID's, and when I need them, the highbeam HID's. You just loseyour DRL's, so your amber DRL light will constantly be on, on the instrument panel. Now I don't know who knew this, or needed to know this, but I thought I would share.
HondaMizzan
Mar 16, 2015 07:11 PM
Rogizzy123
Mar 29, 2008 01:28 PM
aznnightmare9
Jun 4, 2007 03:48 PM
mrq_cool
Jun 24, 2006 01:37 AM
Hairball
Jun 2, 2006 02:19 AM
