inspecting idle speed
Old Mar 29, 2015 | 03:15 PM
tilo's Avatar
Default inspecting idle speed
On a honda accord LX, 4 cylinder how do ins the idle speed? How would I also ajust it if the idle speed is not where it should be.
Old Mar 29, 2015 | 04:39 PM
What year accord?
Old Mar 29, 2015 | 06:20 PM
tilo's Avatar
Originally Posted by PAhonda
What year accord?
It is a 2008 honda accord
Old Mar 29, 2015 | 08:34 PM
I don't have an 08 manual. There should be a sticker in the driver's door jamb or under the hood with the idle speed. When the engine is at operating temperature (when both radiator fans turn on), the rpm should be around 750. Make sure everything is turned off, so there is no load on the engine.
If your idle is out of spec, I would not start by adjusting the idle. Typically, you would want to find any vacuum leaks, etc if the idle is higher than normal. Cleaning the throttle body and both sides of the throttle plate using some throttle body cleaner is a not a bad idea.
I think your accord is drive by wire, so I don't know if opening the throttle plate will cause issues. Hopefully someone else can give their opinion on this.
Old Mar 30, 2015 | 12:05 PM
I think you have to use a Honda computer hookup to adjust the idle. That was true even for my 2003 LX 4-cyl which was NOT a motorized throttle. Even for the 2003 that adjustment was done in the software not in the hardware.
socaldave34
Oct 18, 2012 06:09 PM
irhunter
Mar 23, 2011 04:49 PM
Spadinator
Oct 23, 2010 12:50 PM
games1378
Oct 5, 2006 11:59 AM
fireballer44
Aug 26, 2006 05:48 PM
