Instrumental cluster lights and dash lights not working
Old Feb 4, 2017 | 07:27 PM
djkurious's Avatar
Default Instrumental cluster lights and dash lights not working
94 ACCORD 4-CYLINDER AUTO
So I'm having a problem with the instrument cluster lights and dash lights not illuminating when the headlight switch is on. This is what I have checked so far:
-Swapped 15A small light fuse 3 times, same issue.
-Swapped dimmer with dimmer from another accord, same issue, no instrument panel.
-Swapped suspect dimmer and it works on another accord.
-Continuity on black wire to ground.
-No voltage on red wire.
-No voltage on red/black wire.
-Jumped red/black wire with ground on the dimmer switch, still nothing.
-Ran a wire from battery positive (+) to red/black wire instrument cluster and the lights illuminated.
-Headlight buzzer (buzzer that lets you know the lights are still on) works with fuse in. Without fuse no sound from headlight buzzer.
-Swapped headlight switch with another accord, still doesn't work. Suspect headlight switch works in another accord.
Seems to be a disconnect from headlight switch to dimmer red/black wire.
Hazard lights switch works. P,R,D,D4,D3,2,1 all illuminate.
What else should I be checking?
Old Feb 4, 2017 | 09:31 PM
At the headlight switch, check that the red/grn wire has voltage. Try with the key off and key in the II position (not sure if the ignition switch powers this wire or not).
Old Feb 5, 2017 | 08:22 AM
djkurious's Avatar
Thanks for your reply. Red/green does have 12 volts on the multimeter when the headlight switch is on without the key. With the key off and in the ll position it doesn't have voltage. Just for testing I ran the red/green to the red/black and the instrument cluster lights illuminated.
Old Feb 5, 2017 | 10:39 AM
The red/blk wire starts at the combination light switch. It splits and goes to the gauge cluster and dimmer. Where did you jump power to the red/blk wire? Try jumping power to the red/blk wire at the headlight switch.
Old Feb 5, 2017 | 10:01 PM
djkurious's Avatar
I went from the red/green to the red/ black and I received illumination in the cluster. Guessing I need to follow from where it splits as stated above and look for a short.
Old Feb 6, 2017 | 09:32 AM
So you jumped to the red/blk wire at the cluster, or at the combination light switch?
Old Feb 6, 2017 | 04:03 PM
djkurious's Avatar
​​​​​​​I jumped the red/black that is connected to the dimmer to the red/green at the combination light switch.
Old Feb 6, 2017 | 07:06 PM
Humm, I've seen this issue on the 4th gen's before where a "break" in the wire has happened before....
Old Feb 6, 2017 | 09:05 PM
Here is a thread talking about a similar problem with the same circuit. I'm curious in where the red/blk wire has the break.
https://www.hondaaccordforum.com/for...hts-out-52915/
Jjones1996
Mar 5, 2016 07:05 AM
Uberpippi
Feb 1, 2013 10:09 PM
billyspvy
Jul 28, 2012 06:10 PM
LaGirl
Apr 24, 2012 05:29 PM
edtheace
Nov 27, 2011 11:40 PM
