Intermittant starting issue '02 V-6
Old Nov 5, 2015 | 08:12 PM
The main fuel relay, aka main relay supplies power to the fuel pump.
When the car is not starting, try spraying starter fluid into the throttle body and see if that can get the engine to run.
To test for power at the fuel pump, you need to backprobe the fuel pump electrical connector. There is an access panel in the trunk of the car to access. The blk/yel wire going to the pump is the power supply from the main fuel relay. Use a volt meter or a 12V test light connected to a good ground to verify you are getting voltage to the fuel pump.
Old Nov 6, 2015 | 08:52 AM
Enne's Avatar
I just posted this on another help post but have you considered the ERG valve? A bad one can cause rough idling, severe sputtering/kicking and causing the engine to die, especially right after starting (if it will start at all), as in, you turn the key, it starts, it dies after about 2-4 seconds; unless you have your foot on the accelerator, then it'll run. Does it run better above 2000 RPMs? Replacing the one in my Chrysler stopped it immediately. I could smell fuel as well when first starting it up.
Random question about the fuel quality since it was brought up, I've started putting plus in my '99 Accord (it's been running on regular), do you see any issues with that? I drive it about 50 miles a day, 5 days a week, to work.
Old Nov 6, 2015 | 09:16 AM
shipo's Avatar
It is highly recommend for you to never exceed the fuel requirements for any car. Said another way, if your car recommends Regular, it is not good to burn mid grade or Premium. That said, if you have a car, our GTI as an example, which can run on Regular and yet deliver better power and economy on Premium, then running the higher grade of fuel is certainly a good thing.
So, why is it *not* recommended to exceed the manufacturer's fuel recommendations? Higher grade fuel actually has a slight reduction in available power, and due to its slightly lower combustion temperature, not only will there be a slight reduction in power and mileage, but there will be a slight increase in combustion chamber deposits.
Long story short, if your Accord calls for Regular fuel, burn Regular fuel.
Old Nov 6, 2015 | 11:17 AM
Enne's Avatar
I see, good to know. I suppose I can check my owner's manual for what it calls for (I assume regular). I wasn't aware of plus and premium having less power/mileage output but it makes sense.
Old Nov 6, 2015 | 05:02 PM
redraptor's Avatar
Cool
Oh yeah, starts with ether.
Got the plug cover off tonite and have been periodically running out to start the car to catch it acting up and test for voltage on the restart. Of course, so far been starting and running like a champ. And that's the bitch. If it acted up while driving I would have changed the pump already. Seems to be a cold start issue. My son doesn't have a lot of money to throw at it so I gotta be right or eat it myself. He's driving wifey's Pilot so need to fix this.
Old Nov 6, 2015 | 05:11 PM
redraptor's Avatar
Cool
Never did the EGR service on it when it was newer so I assume the ports are plugged solid and non functional. The sputter & die is no fuel. The pump isn't running after it charges the system from the key turning. Then, after numerous tries, all of a sudden when you try to start it the pump works after you let go of the key. Smells funny but purrs like a kitten.
djstylze
Jul 9, 2010 01:17 AM
cincyred5
Jun 23, 2009 07:00 AM
Rayman4449
May 14, 2008 11:29 PM
ufosearch
Apr 17, 2008 03:48 PM
MHFry1
Dec 23, 2007 05:30 PM
