Issue With Changing Tire
Old Dec 19, 2010 | 09:33 PM
Dbetzel's Avatar
Default Issue With Changing Tire
My wife has a 2007 Honda Accord. Earlier today, I tried to change the passenger rear tire. Thought that it should be pretty easy, but I must be missing something obvious. I removed the 5 lugnuts; the tire is jacked off the ground high enough so that it will spin. BUt I can not get the tire to budge. I sprayed some WD-40 on the lug nuts thinking that maybe the tire was just really stuck on the axle. No luck. I can not get it to budge. Does anyone have any idea of what I can do? Thanks!
Old Dec 19, 2010 | 09:56 PM
I've occasionally had to kick the tire real hard because it's stuck on the hub with corrosion. Make sure the car is supported real good, not just a jack.
Then put grease on the center-hole of the rim so it's better next time.
Old Dec 19, 2010 | 10:15 PM
Hello there New Member...Welcome to the HAF..Now Go out and Kick That Tire..
Old Dec 20, 2010 | 09:06 AM
Dbetzel's Avatar
Default THANKS! One good swift kick did the job!
You guys were a great help! Thanks!
Old Dec 20, 2010 | 10:55 PM
Arrow Your Welcome Sir...
We try to help all our members with good correct answers...
Old Dec 21, 2010 | 03:31 PM
00AccordLX5spd's Avatar
Registered User
Haha sometimes the best approach is the "caveman approach" - hit it really hard with something. Quite often, that is the wrong approach though... I have learned the herd way before. Once I had a lug nut get stuck (I already had it about halfway off) when taking off my front tires to change my pads & rotors. I just tried to force it loose using brute strength and broke off the entire lug with the nut still attached. Since the hub is pressed on (and I don't own a hydraulic press,) I had to pay a local shop $85 to remove it just to replace a silly $2 lug.
Old Dec 22, 2010 | 08:47 AM
Hey Jon! Haven't seen you in awhile. Nice to hear from you.
arvetus
Jun 16, 2015 09:11 AM
imdawrlus
Aug 11, 2012 04:21 PM
litz
Aug 17, 2009 06:31 PM
cyclo
Dec 11, 2007 02:53 PM
hidehide
Jun 11, 2006 11:02 PM
