Changing tire advise...
Old Jun 10, 2006 | 05:43 PM
hidehide's Avatar
Default Changing tire advise...
Right now the car is running on 3 stock tire, which is V rating.
And by some reason, the car has a new H rating tire, same series as the stock.
Now Im planning to change the tires..
The H rating tire, on the left rear, probabily have been running for half year, it is still in good condition.
So how should I change the tire??
Should I change all the other 3 old V rating stock tire to 3 new H rating stock tire?
Is it ok to have one used for 6 months tire running with 3 new tires??
Thanks.
Old Jun 10, 2006 | 07:16 PM
sir_nasty's Avatar
Default RE: Changing tire advise...
you can just change the other three but you run the risk of odd vibrations... Ideally you should do all 4 but if you can't then changing just those 3 is going to be the best route... just be aware of the fact that it could feel a bit funny at times... your H rated tires are good up to 130... the V rating is higher...
Old Jun 11, 2006 | 10:43 PM
hidehide's Avatar
So basically, if you are driving under 130, running H rated and V rated tires are not bad at all??
Old Jun 11, 2006 | 11:02 PM
RTexasF's Avatar
Super Member
I think it boils down to budget. If you can swing four new V rated tires then do so. It that hits the wallet too hard go for three H's but have all four balanced.
arvetus
Jun 16, 2015 09:11 AM
imdawrlus
Aug 11, 2012 04:21 PM
Dbetzel
Dec 22, 2010 08:47 AM
litz
Aug 17, 2009 06:31 PM
cyclo
Dec 11, 2007 02:53 PM
