jdm f22b vtec swap wont start!! please help!!!
Old Jun 28, 2011 | 07:18 PM
Jojo97's Avatar
Default jdm f22b vtec swap wont start!! please help!!!
i swapped in a jdm f22b vtec into my 97 ex accord, and i swapped the oil pump and the crank position sensor, and all the other components. and it just wont run. it acts like it wants to start but it wont. all the timing is correct, i cant fiqure it out... if anybody has any ideas please help!
Old Jun 28, 2011 | 07:24 PM
F22b vtec as in what? I'm assuming SOHC as I think the DOHC was non-vtec.
The first thing you will want to do is check for spark.
Old Jun 29, 2011 | 10:26 AM
TURBOKRAUT's Avatar
did you pinch any fuel lines ?
wouldnt you need to upgrade you fuel pump to compensate for the extra cylinders?
Old Jun 29, 2011 | 12:07 PM
Tek310's Avatar
extra cylinders?? they are both 4 cylinders
make sure to double check your connections, make sure your vacuum lines are all right. check your plugs. make sure ignition timing is right.
Old Jun 29, 2011 | 06:48 PM
TURBOKRAUT's Avatar
whoops
jdmxtom
Aug 31, 2011 06:11 PM
g22cd5
Nov 14, 2010 07:14 PM
PTVDesign
Oct 28, 2008 09:20 PM
wjmj
Jan 7, 2007 10:57 AM
