Just had my error code assessed, but I need help with the part names
Old Oct 26, 2012 | 04:17 PM
LordAccord's Avatar
Default Just had my error code assessed, but I need help with the part names
Hi all, I had a p1456 error code, and an EVAP leak. I had a smoke test done today and was told (it was by the rear of the car) that I need a new canister and a bypass shut valve, or something like that. I was told I need both the canister (and whatever else it was) which are sold seperately.
I'm not even sure what this system is called, so is there a diagram or something I can look at to pick it out exactly? I was told that I can only get the parts from Honda. I'd just like to learn a little more about the job before it's done on Monday.
Also, this leak seemed to be vapor rather than gas itself, does this negatively affect fuel consumption?
Thanks in advance
- Accord 1998 EX V-6 3.0.
Old Oct 26, 2012 | 10:27 PM
#6 is the EVAP canister. It's mounted under the car, below the left-rear seat. There's a couple solenoid valves down there, but the vent-shut valve (#8) is a common failure.
Attached Thumbnails Just had my error code assessed, but I need help with the part names-98-fuel-evap.jpg
BigShelby
Dec 18, 2015 09:36 PM
Alexander Harden
May 20, 2015 06:01 PM
LaZy_GuRl
Jun 2, 2007 08:19 AM
CasualObserver
Dec 14, 2006 02:06 AM
theycallmerickjames
Jul 9, 2005 01:12 PM
