just a question Plz.
Old Jan 29, 2013 | 03:37 PM
csk.jfoxx's Avatar
Default just a question Plz.
on the tranny where the vss bolts into. what is that piece the vss bolts into. looks like if you ubolt the vss you can unbolt the another piece below it. what is that. thanks.
Old Jan 29, 2013 | 07:31 PM
Not sure what year trans we are talking about....but on most of the newer ones (I'm stuck in the late 80's )that is the speedo holder and gear.
The gear makes contact inside the trans, as the trans is spinning the gear moves sending the motion to to VSS (there is that little drive pin between them) which translates that into electrical "pulses" that go to the speedo PCB....which then translates that into how "fast" the car is moving.
Jeysin
Jan 25, 2008 05:46 PM
cache
Apr 16, 2006 04:43 PM
95SiR
Apr 13, 2006 03:27 PM
redwaterfried
Feb 4, 2006 09:16 PM
jsyjordan
Jan 13, 2006 03:05 AM
